Brand new plugged in once now no power
SOURCE: i can not find the reset button on my DeWalt Radio.
take the two aa baterys out and the put them back this worked 4 me
SOURCE: my dewalt radio stopped working. I plugged it in,
Check fuses inside. Check fuse and connections in plug. If this is a 110v radio there is one on transformer winding.
SOURCE: I got brand new GE air condition and accidentally
That is a circuit protector...just like what you would see on a bathroom outlet. It is possible the switch is bad and when you pressed test...it stuck in the open position and will not reset. I would unplug unit and firmly press reset from a couple angles. You may end up getting a new switch for it. Sorry for your inconvenience.... If brand new maybe you can return it?
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1 -
TO TEST A GFCI:
Start the generator. Turn the auto idle switch off. Push in the TEST button (A) on the receptacle.
The RESET button (B) will pop out. Power is now off at the receptacle.
If the RESET button does not pop out, the GFCI is not working. Do not run
generator until the problem can be corrected. To restore power to receptacle,
push the RESET button in. If the RESET button pops out during operation,
stop the generator and check the generator and equipment for defects.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized DEWALT
service center. To locate a DEWALT service center nearest to you, call 1-800-4-DEWALT
Joe
Thanks for choosing Fixya!
