SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
SOURCE: replacing headphone connector
The impedance or resistance of the two different sets of wires might be different. The higher the impedance the less signal. If your cable is long enough you are better off spending the five or so dollars for a new plug. Red is right, green or blue is left and copper is ground.( Usually) Unfortunately not all manufacturers agree. Also what could have happened is a short between the wires that you soldered.Make sure they are physically separated from each other and insulated.
SOURCE: no headphone jack on samsung tv,so i got a ,y
Headphone output is usually dependent on the source's volume setting and are not a good way to transfer signal between devices. RCA is the way to go as it is independent of the volume control. Many TV's have a setting for the audio output to select variable or fixed (independent of the TV volume setting). Look for it.
SOURCE: Need headphone solution for Panasonic c12lcd tv
I have a Panasonic viera 32in lcd hd tv. I'm trying to hook up headphones but there's is no apparent audio output jacks. But there's is only one digtal output jack! is this the jack ? and if it is, what cables do I need to make the headphones work? or am I forced into by an amplifier
First thing is you need to have a signal going to the headphones for them to work.
If you are getting a signal the green light should be lit.
If only the red lamp is lit the headphones are not getting a signal.
If hooked into a television you should have them plugged into a Fixed Output not variable output..
If you only have a variable output then you must turn the speakers off on the television and then turn the volume up on the TV in order to send a signal to the headphones.
If you are using a amplifier make sure you are using the correct output. Tape Monitors generally will not work as this output is not amplified.
Lastly try using an rca to headphone adapter and plug them into a headphone jack.
Don
