SOURCE: No picture, hear sound, television will shut off after a few seconds.
Take out the bulb (back left hatch door) look to see if the element inside the bulb is broken or blackened - (replace bulb) if the bulb looks OK then it's the ballast that fires the bulb (service call).
Raf
SOURCE: television
tbrace, your picture tube is getting a little tired, the "IK circuit" is causing the blanking of the video because the tube is not returning a large enough signal back to the IC that monitors it. Theres only one fix (besides replacing the tube) for your set and that is to turn up the screen control. You have to remove the back from the set and on the right hand side there is a large plastic part called a flyback transformer, with a heavy wire coming out of the top which goes up to the picture tube, mounted on the front of this transformer is 2 black blastic "philips type" controls, one over the other look closely and one will be marked focus(do not turn that one) and the other is the screen control, turn the set on and SLOWLY turn the control clockwise until you see a bright picture with white lines in it, once you see the lines turn it back until they disappear, (check several channels to be sure they are gone) your done, may last 3 weeks, may last a year, it`s all you can do, BMW Rider
SOURCE: Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
SOURCE: Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
SOURCE: recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
