I haven't had much luck with Nero. I find a newly installed Nero works well but doesn't last and after a few shutdowns and restarts Nero stops being efficient and after uninstalling Windows don't work so well - usually end up formatting the hard drive and reloading everything...
I not sure about nero had a quick look it seem it can with xp.why not use the windows built in tool to create the image
if you have a second hard drive you can set it to update the image automatically other wise if you add new programs or games you will have to keep making new disc images.
SOURCE: DVD & CD drives not recognized after uninstall Nero
plain reinstallation of windows won't solve the problem, either you edit your registry to clean it up of all the nero entries or to install windows in clean mode, I mean, you need to reformat or remove windows completely first fron your system.
SOURCE: Samsung DVD writer SH-S182 problem
try a different power connector from psu,do not share same as HD!!should work!!
SOURCE: G-drive media problem
install the drivers for the drive, right click my computer choose manage and then disc manage choose the g drive, right click on it and change the drive letter to w and it will work.
SOURCE: want to burn .nrg Windows XP bootable image file in a blank cd.How i do this ?
You can use CDBurnerXP (free) and convert NRG to ISO then burn the ISO using the same program
http://www.cdburnerxp.se/.
SOURCE: i want to burn videos to dvd disc.. can i do it
No, you can’t. This one is a CD burner and DVD player. Not a DVD burner.
Testimonial: "oh! really!... thanks a lot! im going crazy looking for the right software, not even thinking that it was the drive. "
