SOURCE: brother typewriter
make sure you power on the typewriter and space bar carrier until middle of bar. flip open cover and put ribbon in rear end first then push front to lock. i have to then turn orange knob on top of ribbon cassette in direction that arrow points just to tighten ribbon and that usually will lock the ribbon cartridge if it lock with first push. also, the ribbon itself goes in front of the 2 guides that stick up higher than the rest. hope this helps. if not you can look at brother website under that model and look at manual. it shows you how.
SOURCE: in need of a brother GX-6750 typewriter owners manuel please help
First press the Code key and Q simultaneously. That will reset the wheel position. If it clicks or otherwise fails to type properly, pull out the wheel and inspect it. One or more of the types may be bent. In that case, the wheel needs to be replaced. Good luck finding the part.
SOURCE: Brother GX-6750 Typewriter printing problem
have you tried chaging the daisy wheel with a known good one? If yes, have you checked to see if the hammer is in a good condition?
SOURCE: My typewriter (Brother GX-6750) does not print correct letters
look for bent or broken spokes on daisy wheel .turning unit off for 20 seconds and back on should reset the daisy wheel home position. probably the daisy wheel.
SOURCE: brother typewriter correctronic gx-6750...prints
Make certain the printwheel is latched fully into position. Observe the hammer movement while typing slowly NnNnNn. If the hammer does not come to rest at the same position every time the hammer cams are at fault. Make sure there is nothing interfering with the printwheel movement (like the correction tape or ribbon)
