L
Linda Clokie Posted on Feb 11, 2018
Sansui sports mP3 player (yellow in colour) manual. How can I charge the player what do I need as have misplaced the charging cables
5 Related Answers
A
Anonymous
  • Posted on Jan 07, 2008
SOURCE: Isonic Snapbox mp3 player wont turn on or charge
get a new mp3
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Dec 28, 2008
SOURCE: my sansa mp3 player won't charge or connect
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Anonymous
  • Posted on Oct 27, 2009
SOURCE: i-scream mp3 player (AV-1)
i have no problem with the charge on my i-scream av-1 mp3 player, but when i add songs from the computer onto it from the usb cable, as soon as i disconnect, and i try and listen to the music i just put on, it wont let me play it and it has deleted all of the other songs i had on before i added more.
Anonymous
  • 6 Answers
  • Posted on Jan 07, 2010
SOURCE: i Have a Hip street digital mp3 player 2 GB and it wont charge
try this.. charge your mp3 player but put it on
Anonymous
  • 7 Answers
  • Posted on Feb 23, 2010
SOURCE: How do I charge the MP3 Player?
Have you got the cable that go's between the mp3 and the computer ?. If you have then that is haw you charge up your mp3 player, you can leave it hocked up to your computer while it is charging.
Why can't I charge my mp3 player?
It could be that your USB cable is just a synch cable, not a charging cable. A synch cable connects your MP3 player to your computer so you can transfer (automatically or manually) MP3 files between the two. If you can see the player in the Windows Explorer on your computer as a "Removable Device", it is a sync cable.
My insignia sport MP3 player froze so i turned it off and now it won't turn on, i tried to charge it thinking it was low baterry but it doesn't charge either
I had the same problem. The reason is because you have not charged your player, in a while.
First of all, try this.
Reset the Insignia Pilot if it freezes during normal use. To reset the device, press and hold the "Power/Hold" switch to the right for approximately 10 seconds until the screen turns off. The "Power/Hold" switch is located on the top of the player.
If that does not work, you need to remove the battery and then put it back.
Here's how to do it.
https://www.youtube.com/watch?v=29ULLzZqHLI
Then plug your cable and wait until it comes back to life. Be patient, it may even take a couple of days, until a full charge is accomplished.
2helpful
User manual for Hands-Free Noise Cancelling MP3 Player sport mp3
For everyone having problems with C.R.A.P. products made in China, like I am currently having with the W1B/MP3 headset, don't buy products that are MADE IN CHINA! Exist without them if you have to. They are laughing at us Americans who buy their J.U.N.K.
1helpful
Need manual for sport headphone mp3 wma player
Hello, welcome to Fixya!
You can charge with the cord using your computer. Connect the cord to the player and the usb part to your computer. Your computer will recognize and charge the player.
I hope the above is clear.
Good luck.
2helpful
I seemed to have misplaced both my Sansa Manual and cable How do I go about charging the battery in My Sansa MP3 player
You can download the manual from
http://www.sandisk.com/sandisk-support/warranty-and-user-guides
You can order the cable from
http://shop.sandisk.com/store/sdiskus/en_US/DisplayProductDetailsPage/parentCategoryID.11443000/CategoryID.11449200/productID.103565200
1helpful
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • 0helpful
    Mp3 insignia sport
    is the battery in correctly and is the usb cable fully inserted on the computer end if your going throug a usb multi-port hub make sure its not over loaded with too many devices
    if no hub try a different usb port or a different cable
    2answers
    Sansui SAN1880 80g dvd recorder no colour
    Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
    Thanks
    Rod
    Can't charge battery
    Try another cable. Some don't work
    In these otherwise good machines, the battery may come loose. Then they won't charge no matter what.
    Top Sansui Audio Players & Recorders Experts
     Grubhead
    Grubhead
    ADMIN Andrew
    ADMIN Andrew
    Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
