The shocks have failed in it. It is an easily overlooked problem and causes all the issues you just said.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
SOURCE: series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
SOURCE: kenmore elite steam front load washer
take the shipping materail out,,remoce the 4 bolts on back of machine,,the washer should of came with a little wrench...after removing shipping bolts put the 4 white sluggs or vcaps in hole ,,pull bolts with rubber or plastic grommet..onthejob
SOURCE: Washer is always "out of Balance" during the spin cycle
Way to go. A+ to you. Good Luck in future.
SOURCE: kenmore elite washer leaks water in spin cycle
You need to replace your pump. Make sure you have the washer either on something that will absorb water, or fix it outside/garage. Because these pumps hold extra water and that is why it is not recommended to keep them outside to do laundry in colder climates. The water can freeze in the pump and wreck it. Good luck. They actually are pretty easy to replace.
SOURCE: GE top load washer Model
Look in the pump and see if maybe something is clogging it. Check the belt.
This video shows how to get into the washer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
