Music Logo
David Tanner Posted on Feb 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the base detach from the Yamaha CVP-601 for transportation
DROPNDEAL
Level 3:
Top Expert:
  • Yamaha Master 2,931 Answers
  • Posted on Feb 12, 2018
DROPNDEAL
Yamaha Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
931108
Points
21770
The Yamaha CVP-601 can be transported fully assembled. However, yes, it can be disassembled if desired.
Your owners/operators manual will detail the procedure.
Click here if you do not have one: Yamaha Clavinova CVP 601 Owner Manual Assembly Preparation Before...
Does the base detach from the Yamaha CVP-601 for t - helpful-3b2ijbsxbsspfgylo4cpmgak-5-0_3.png
2 Related Answers
Anonymous
  • Posted on Feb 27, 2011
SOURCE: Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
magna buff
  • 3828 Answers
  • Posted on Nov 03, 2016
SOURCE: My yamaha cvp 601 no longer turns on. What could be the possible problem?
strange and annoying
any power surges noticed
could be wall plug lead
or the 240 volt internal power transformer problem
26338855-vgifjk0cmh4fityltrfmb02q-5-0.jpgyamaha-cvp-601-no-longer-turns-could-vgifjk0cmh4fityltrfmb02q-5-2.jpg
3helpful
2answers
Clavinova CVP-85A. Where can I get a service manual or schematic diagram?
David
What is the problem you are having?
I have some info on CVP85/87 which shares the same service manual.
Let me know and I may be able to pass on some info.
2answers
User manual Yamaha Clavinva 35
Contact Yamaha customer service in your country. They may have it on their site, but if not, they would have access to one top forward to you.
1helpful
2answers
Where and how can I buy a replacement keyboard for Yamaha CVP 305M? Thanks, Michael
There is a well documented problem that occurs with the keybed on some of these models due to a manufacturing fault. Take a look at the keys that are sticking. Is the gap on either side of the key the same ? If not then the key normally leans slightly to the left rubbing on the adjacent key causing the sluggish action. The fixing tab at the back of the key breaks causing the spring pressure to push sideways.
You can just replace the offending key but the problem will eventually return. You could replace the whole keybed but this is a very expensive fix.
Keys are around £ 15.00 each.
Replacement keybeds around £ 450.00
Visit www.beckettsmusic.co.uk
Search for VU101 via the search box.
Wiring diagram yamaha cvp 303 clavinova
i have a broken cvp-85a but the pedals are ok so?
Jan 14, 2013 • Music
Need manual for CVP-700 english version
how opening yamaha cvp-700
Jun 30, 2012 • Music
2answers
I have a clavinova CVP 409. If I try to record using an external memory device (external Hard drive or memory stick, a message appears; DISC ERROR. Can you please help me solve the problem or direct me...
I SUSPECT that the CVP 409 will ONLY talk to the Yamaha USB floppy drive, not a hard drive or memory stick.
The internal drivers for these musical instruments do not have the "smarts" to talk to the wide variety of peripherals that PC's are able to.
1helpful
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
