hi kath.
see if this helps you out,if not go to the link at the bottom. To see your remaining allowance, call 2345 free from your Vodafone Pay as you go mobile. If you don't have your mobile with you, call the Pay as you go credit line on03333 048048 from any other mobile or landline (standard call charges apply)
Do you mean the Vodaphone tariff?
Vodaphone says:
You can opt out of Vodafone EuroTraveller at any time by dialling 5555 or texting REMOVE to 40506. On the day you opt out, Vodafone EuroTraveller will be removed from your account immediately. You'll be billed the daily charge if you use your phone in the Europe Zone on that day.
You should call Vodafone and tell them that your phone has been stolen. They will block the SIM card so that no calls can be made on your account, and will advise you what steps you need to take to get a replacement, depending whether or not you have insurance.
UK WAP gateway settings The following table shows basic WAP gateway setup information for the main UK mobile phone operators. The menu options differ between handset manufacturers. Some of the common menu fields explained:Bearer type: There are two types: GSM or GPRS. GSM works by dialling a dedicated WAP dial-up number and should work on any WAP-enabled handset. GPRS is a newer technology, and only works on selected handsets. GPRS is an always-on service that is billed per-kilobyte, and not as GSM, which is billed per-minute.Dial-up number - The telephone number that your WAP browser needs to dial to connect. (Not required for GPRS)
GPRS APN - If connecting over GPRS (as opposed to dial-up), you need an Access Point Node address, so the network knows where to direct your request. See our GPRS for full UK GPRS settings
Username and password - Note that these are case sensitive, and should be typed in as shown
Gateway IP details - WAP works by routing traffic through a Gateway that handles optimising the content efficiently. The address is made up of a series numbers separated by dots. This may also be referred to as the WAP Proxy Server address.
Homepage - This is the main page provided by a network operator... The front-door for access to content provided via your network operator
