Most likely a clogged pump drain find it below the drum usually under a plastic lid bottom left if not under the lower panel below the door
find the 3 screws and remove the cover panel and clean the pump by twisting the pump valve cover counter clockwise
WHIRLPOOL CABRIO WASHER ERROR LD
The Cabrio Washer LD error code stands for Long Drain which means the control has recognized the water in the tub is not draining fast enough during the cycle.
Testimonial: "Thank you! This is a great help!"
SOURCE: LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
SOURCE: Won't do anything
This is another possible solution, more than likely most people will expierience clogs. I had the same problem today, upon removing the drain pump I noticed one of the dark blue wires was off of the connector that plugs into the pump, seems these are held in place by a "splice connector", and is a simple fix, after you unplug it from the drain pump take the connector and pull from the front and rear to open the splice jaws, re insert the wire and push back together. Plug it back into the pump, and that's it!
SOURCE: keep getting LD error code on whirlpool cabrio washer
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
SOURCE: Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
SOURCE: whirlpool cabrio giving error message LD-what is wrong
Long drain error can be caused by something plugging the drain hose or a kink. Tale it off th drain while it is pumping out and check for a good flow. If the hose is ok the pump may have an obstruction causing low flow and it will have to be cleaned out.
The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error comes back then the control board needs to be replaced..
If this was helpful please rate me Thanks
