SOURCE: Dimplex Model 3087S
I have the dimplex dancing fire W..20 and I've just managed to change the bulbs!!!! Take the coals out and turn the fire upside down. In the bottom you can get your hand in the middle and unscrew the bulbs. There are two and they face each other. It's a real pain and a large mans hand won't fit. You meed two 60watt candle small screw to replace them. hope this helps.
SOURCE: dimplex manual
HI
you could try here at or even email/contact them these should be able to give you the manual
Dimplex Heating & Fireplaces
riz.
SOURCE: Dimplex PW4 timer not working with heaters
In UK, you can call 0845 600 5111
The manual is very unclear about:
1) Wiring.
2) Resetting the timer when encountering a problem due to surge, power outage, or malfunction.
3) Troubleshoot section is missing.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
