Televison & Video Logo
Bobby Shaw Posted on Feb 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I’ve connected a Sony soundbar and subwoofer up to my Sanyo dp32640 television using headjack analog, but sound still is output via tv speakers rather than jack.
raysaw
Level 2:
Sergeant:
  • Expert 267 Answers
  • Posted on Feb 17, 2018
raysaw
Expert
Level 2:
Sergeant:
Answers
267
Questions
Helped
96705
Points
732
Look in the TV menu to see if you can turn off the built in speakers or at least turn them way down.
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on Oct 19, 2008
SOURCE: BA735 no sound but sound card works in analog mode.
this should be pretty easy to diagnose. both speakers have mini jacks right? if so, and you plug one pair of speakers in on say, port "A" and you get sound then if you plug your other speakers in on port "A" and you don't get any sound, the problem is with your speakers.
Anonymous
  • 77 Answers
  • Posted on Feb 25, 2009
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
Anonymous
  • Posted on May 09, 2009
SOURCE: Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
smarthome2
Frank Fulton
  • 1114 Answers
  • Posted on Jun 25, 2009
SOURCE: Sony HT-CT100 soundbar + STR-DG720 = Yes misery, no audio
It's not going to do whayt you want. On the premise that you can't run a dedicated receiver to a dedicated receiver. One processor is not going to override another. The soundbar is a "self contained" closed system. Much like Bose products. I understand what you are looking for, it just can't be done with this product. Options: replace the sony soundbar with a passive polk soundbar or similar and keep the AV receiver or: Return the AV receiver and use the nice, but limited sony amplified soundbar. Hope this helps
Anonymous
  • 125 Answers
  • Posted on Aug 25, 2009
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Testimonial: "very fast, thanks for the help!"
Connecting samsung sound bar to sanyo fvm3982 tv
Here are steps to connect a Samsung soundbar to a Sanyo FVM3982 TV using an optical cable:
  1. Locate the Optical Out port on the back of the Sanyo TV. This port will be labeled "Optical Out" and is usually covered by a small protective cap.
  2. Remove the protective cap from the Optical Out port and plug in one end of the optical cable.
  3. Connect the other end of the optical cable to the Optical In port on the Samsung soundbar. This port may be labeled "Optical In" or "Toslink".
  4. Turn on both the TV and the soundbar.
  5. On the Sanyo TV, use the remote to navigate to the audio settings. Look for an option to set the audio output to "External Speakers", "External Audio", or "Optical Out". Select this option.
  6. Adjust the volume on the Samsung soundbar using its remote control.
Once these steps are completed, the sound from the TV should be played through the Samsung soundbar. If you encounter any issues or don't hear any sound, check to make sure that the soundbar is set to the correct input and that the volume is turned up. Additionally, make sure that both the TV and soundbar are properly connected and powered on.
3answers
How do I hook up Vizio soundbar to Sanyo tv?
Use the left and right audio out from the TV
No sound via philips soundbar hts8100 with philips 52pfl7403d tv
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
1helpful
How do I connect my Sony soundbar ht-ct 260h to my blu ray player etc, I have no optical port or arc hdmi port,at the moment connected through the audio lead to soundbar & tv ?
hook your dvd player up to the tv via hdmi, then take the optical audio output from you tv to the soundbar. Make sure to enable to audio output jack in the tv setup menu as some manufacturers disable this jack by default.
How do I connect a Goodmans sound bar to my Toshiba Regza tv as the manual says connect via Aux
hook the soundbar to your axillary output or audio output or speaker output
How do I connect ILive ITO82B Sound Bar to an LG TV?
This will depend on what inputs your sound bar has and what outputs your LG TV has, typically LG have Optical DIgital Audio (Sony TOSLINK), Headphone (Analog stereo), And HDMI reverse audio from HDMI 1 only. On some LG TV's you have to turn the external sound on, and on others it is auto detected, also make sure the TV speakers are off, or you can get weird phasing from 2 outputs (TV + Soundbar).
1helpful
How do I connect Samsung soundbar 550 to sanyo dp55441?
Use the audio out ports on the Sanyo to get audio to the Soundbar. You can use a single digital audio cable or the legacy RCA audio cables. The Audio Out ports are marked in white on the back of the TV. If it doesn't work, turn off the TV Speakers in the TV's menu.
How do you connect a vizio sound bar to the tv
plug in the power to each unit with the provided power adapters, turn the sound bar and subwoofer on, activate the wireless subwoofer link by pressing a button on the soundbar (or remote) and subwoofer, and connect an audio source to either the provided analog or digital audio inputs on the soundbar
Note: When using the Digital Optical input, set source device audio out to PCM
(you can hook to ur tv if it has a R/L audio output, or u can also connect it if your tv has a toslink style digital output. (most LCD and Plasma TV's have them.))
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
