As you don't give the model, I can just give a generic reply.
Most front loaders are belt driven, and some top loaders are.
I think the main thing to look at first is the connection of the drive motor to the tub. If this is a belt - replace it and check the tensioner.
If it is a top loader using a gearbox, then the motor is likely to need either brushes or a new capacitor. Both items should be checked - so -
Belt ok? - Y= go to next question / N = Replace belt
Brushes ok Y= go to next question / N =Replace
Replace Motor Run Capacitor.
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Hi there....you havent stated whether its a top loader or a front loader.....top loader 1st.....
usually caused by a defective drive clutch..this will require the drive mechanism to be removed and a relacement clutch fitted
front loader 2nd...this is usually caused by failed spin windings in the motor..worn carbon brushes in the motor.or a failed programmer....
I have the same problem. Just started missing the spin cycles and now I need to find which part to replace.
So far I think it could be: Aged contacts in the Timer, a faulty spin/no spin switch, or something to do with the brake/release mechanisms etc. ..I do know that the problem is electrical because everytime the motor starts the spin works fine; therefore eliminating in my opinion, the mechanical gearbox bits as a cause.
