Drills Logo
D
Dan Rogers Posted on Feb 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hitachi DH24PC3 SDS drill is dead. Initially it would only work when pointing down now it has stopped completely. Ive dismantled & cleaned it but still not working, any ideas so i can get parts?
Pieter Vleeshouwers
Level 3:
  • Hitachi Master 2,029 Answers
  • Posted on Mar 11, 2018
Pieter Vleeshouwers
Hitachi Master
Level 3:
Answers
2029
Questions
0
Helped
4113554
Points
7389
Control of the electric field wires and the 2 carbon brushes and the switch
https://www.kruis.nl/onderdelen/viewer/?m=hitachi&t=DH24PC3_0&p=dh24pc3
5 Related Answers
Anonymous
  • 19 Answers
  • Posted on May 05, 2009
SOURCE: sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
Anonymous
  • 211 Answers
  • Posted on Dec 16, 2009
SOURCE: my hitachi drill is working funny
hi
try to charge the battery at full level and see what happens then.
regards savumihai71
Anonymous
  • 8 Answers
  • Posted on Feb 11, 2010
SOURCE: I have a hitachi dh38ye hammer drill. Is their an
sds plus to max adaptor....
Anonymous
  • 2176 Answers
  • Posted on Aug 15, 2010
SOURCE: Milwaukee heavy duty hammer drill only works when
could be loose connection at the switch or brush holders. You can go to Milwaukeetools.com to download a breakdown for this tool.
richochet
  • 1026 Answers
  • Posted on Nov 02, 2012
SOURCE: dewalt sds drill dramatically slowed down
tight bearing maybe
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 • Garden
1helpful
Need new trigger
You need Hitachi part number 324-536 (switch, 1p pillar type). Several aftermarket sites carry them like www.ereplacementparts.com.
Brand new Hiyachi DH24PC3 leaking oil from chuck on first use while using hammer only chisel application - is this due to overheating ?
Hi, these impact drills need greese to function properly and some modles leek more than others. As its new you could ask for a new seal, as this is what is allowing the oil to leek. Hope this helps
1helpful
I own a hd50spk hitachi...what drill bits are universal across the brands?
there are 2 main types of hammer drill bits, standard and SDS.
standard bits go in a regular style chuck hammer drill
SDS bits have 2 grooves and 2 elongated holes on the shaft which snap into the chuck
I'm not sure which type you have, but to answer, the 2 types are universal within their types
Jan 01, 2010 • Drills
2helpful
How do I remove an SDS bit stuck in a B&D SDS
the rubber cap in the sds chuck nose is only snap tight try to remove and dismantle the retractable locking pins.
Nov 26, 2009 • Drills
Top Hitachi Drills Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
