Question about Michele Watches
Extra links Michele csx 33 watch band - Michele Watches
6ya staff
SOURCE:
Anonymous
SOURCE: remove the extra links in a luminox 3204 watch band
It was nothing more than split pins holding the links together. I pushed them out removed the links and pushed them back in.
Posted on May 13, 2008
Anonymous
  • 109 Answers
SOURCE: HOW DO I TAKE A LINK OUT OF THE WATCH BAND
Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
Posted on Aug 11, 2008
Anonymous
  • 4 Answers
SOURCE: Remove link from Watch Band
I would suggest that you take it to local jewler or watch repair center, it normally runs less then $10 to remove an unlimited number.
Wal-Mart used to be a good place to go, but have since decided to support only watches that are sold in the store, which are crappy at best.
If you want to do it personally...I would discouage it. It is normally a simple process but without training, can turn into a big problem with minimal effort.
Have a great day!
Posted on Jan 13, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: remove watch band link
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 27, 2009
Anonymous
SOURCE: I just bought my wife a michele csx-36 watch. Its brand
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
Posted on Feb 28, 2010
Am I able to buy 3 links for my Michele watch?
yes contact the manufacture / google it. call with model number.
Jan 31, 2012 | Michele CSX Diamond watch
I didn't wear my Michele CSX 36 w/ diamond watch for a few days..When I went to put it on the time was wrong. So I tried to correct it and now it has not kept accurate time w/in a 24 hr period. Fo
I am pretty 100 percent sure that Michele CSX 36 diamonds only comes with a swiss quartz movement not an automatic movement.
So the problem seems to be that the battery is dying and need to be replaced. Stopping and going is usually a sign of a battery dying in a swiss quartz movement.
So it should be nothing major and just a battery.
Jan 23, 2012 | Michele CSX Diamond watch
MICHELE CSX HAND ALIGNMENT
You don't say if your "CSX" is a battery powered watch or a mechanical or windup type watch. The solution for a mechanical watch is take it to a watchmaker. If it is a battery powered watch you may be able to do it yourself. Not all work the same way so without knowing what a "CSX" is I will give you one way to try. Pull the crown out two clicksHold the lower button in until a hand moves.You have now selected that hand to adjustUsing the upper button now, press and adjust the hand until it lines up with 12Now hold the lower button againAnother hand should moveUse the upper button to adjust this hand to the 12 positioncontinue this until all the hands line up with 12Press the crown in and press the upper button,the chronograph hands should startPress the upper button again and they should startPress the lower button and they should all go to the 12 o'clock position
Oct 21, 2011 | Michele CSX Diamond watch
I need to buy 2 links to add to my watch can this be done can I buy links without replacing the whole band?
yes you can. but you need a particular tool to do it though. you can maybe do it with some household items depending on the brand of watch.
Aug 08, 2011 | Michele CSX Diamond watch
Can i remove links from a michele deco mini watch
Any watch repair shop will usually do it for free or under 5 dollars. You can do it yourself with care and very small set of screwdrivers which are probably about 10 to 20 dollars at any department store. I recommend a shop, and they can usually do that for you in less than 10 minutes
May 05, 2011 | Michele CSX Diamond watch
The red bead (?) on the stem of my Michele CSX watch came off and was lost.How do I get a replacement? Thank you. Patty
I also chipped the enamel on the crown. You should take it to the place you purchased it and they will send it to Michele (actually Fossil) for repair. I had my Michele for 5 years before sending it in to have the crown repaired and have since lost the stem. Prior to that first repair, I did not have any issues with my watch. I really think that the parts used on my watch for the first repair were shotty. Very disappointing, but what do you do?
Apr 21, 2011 | Michele CSX Diamond watch
Watches CSX Diamond: how do I change the battery...
good day,
hope this link below will solve your problem.
watches
May 16, 2010 | Michele CSX Diamond watch
I just bought my wife a michele csx-36 watch. Its brand new. The watch runs for about one day then stops . What do you think it is. We did replace the battery already. Thanks
Dec 14, 2009 | Michele CSX Diamond watch
Watches Logo
192 people viewed this question
Top Michele Watches Experts
Marvin
Marvin
NOEL
NOEL
fitzperfect
Level 1 Expert
Are you a Michele Watch Expert? Answer questions, earn points and help others
