SOURCE: USER'S MANUAL
The best way to get a manualis to contact the mfg.
Olympia 1-800-775-7570
DickyO
SOURCE: Olympia Mastertype 3 Typewriter
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
SOURCE: AX-90 NAKAJIMA TYPEWRITER USER MANUAL NEEDED
Contact Nikajima @ 1-800-809-7138 they are very helpful.
DickyO
SOURCE: how do you fix the daisy wheel for Mastertype 1
It is usually that the printwheel is in wrong. Make sure the pw does not have any bent "petals" on it making it bind.
After it snaps in and closes it should go to it home position. If not keep trying a couple of more times and it should seat in.
SOURCE: I need a manual for
Go to NADIST.com, Click on current models I believe the oly is identical to a Makajima model.
DickyO
