Hi. Just bought a home and the remote for the Hunter Douglas ceiling fan has a button that says "Fan Off". When we push that button, it does not turn the fan off. The speed of the fan button works, and if you turn off the lights and fan using a wall switch everything turns off. But, if you want to not have the fan on but the lights on, the button on the remote to turn the fan off isn't working. So, the fan and lights are on when we only want the lights on.
SOURCE: Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
Try Cheyenne Lamps 2000 E. 17th Street Little Rock AR
501-374-2829
SOURCE: Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
