SOURCE: need product key code for lexmark X2600
For what ? The software installation? I don't understand?
Go to Lexmark's website and get another copy - No key required
Here:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
SOURCE: need help please need product key code of 25 characters for lexmark X2600
ok I am assuming you do not have the label with the product key; so the only way to retreive it is with some product key software. You will get all of your product keys with this software so you may want to write them down and store them in a safe place. You'll get Vista and Microsoft office product keys in case you ever have to reload your system you'll need the product keys to do it.
Go to this website and type the address exactly as shown no "www" in front of it: software.cyberwalker.com/item.php?i=1045.
RIght in the middle of the page is a program called Produkey. I just checks so it is there. Just click on download and follow the instructions to load it on your system. Once the program is loaded run it; give it a few minutes and it will bring up all of your product keys. If you have any questions let me know.
Pls rate this solution.
SOURCE: blank pages
tried re-installing the sortware or going into printer diagnostics in the start,control panel.
and it will run a diagnostic & try to print a test page, & clean the cartriges.
If not the printer's broke
Hope this help's
SOURCE: The error ej on printer lexmark x2600 wont clear
The EJ error code indicates that your printer carrier has stalled. Try to remove the mechanical jam and press the power button.
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier
moves and stops at the loading position, unless the All-in-One is busy.
Note:
If the carrier does not automatically move to the center, turn off the
printer/unplug the printer from the power source and then slide the carrier to
the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge
first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
1.
2.
3.
4.
5.
Rebrick (pull out power supply, black box where the
seconds).
6.
7.
8.
