SOURCE: toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @[email protected]
SOURCE: blades wont engage
check the clutch if it engage then check the cable and belt to if it works make sure all the bolts are tight. usually the belts is too loose or if its a clutch drive maybe the clutch doesn't engage or worn out.
SOURCE: once engaged and start mowing, you can mow for
I have the same problem with mine and its not the air filter. I have a new filter and cleaned it and still does it. I even took the air filter off and it still does it.
SOURCE: Skoda Octavia Ambiente 2004 1.9 tdi, automatic
problem one is the timer control for the heaters ,also check the heaters that they are working ,oil problem ? look under the rubber boot that goes over the oil switch ,pull it back and if oil under the cover renew the oil switch,these motors do suffer from heater light flashing on and i know people have spent megabucks trying to cure it ,its a fault with dash and printed circuits ,but the heaters are not coming on i know because i have driven one with the heater circuit light coming on and i had a extended light on a long wire and the heaters are not coming on ,ignore it just renew the faulty glow plugs,as for EGR valve just pull teh vacumn pipe off the ERG valve and leave disconnect ,more hassle than its worth changing it ,you could end up with a ECU computer .Still a nice reliable motor though and economical
Testimonial: "Thanks for your usefull answer. Afer I stop the engine 2 times from EGR valve, both board alarms have been reseted. What does it mean? Thanks again."
SOURCE: Stop Engine, Low Oil Pressure
If you rev the engine does it go away? What is probably happening is that you have damaged or worn engine bearings. These bearings are designed so that there is a gap(clearance) between the crankshft and the bearing. This gives a space for the oil to pass through. If the clearance is too big the oil will pass through too quickly and the oilpump will not be able to build up pressure, even though the volume of oil pumped is sufficient.
When the oil is cold it is thick and the sensor sees the pressure as normal. As the engine oil heats up it gets thinner and that causes the pressure to drop. Also the lower the RPM the lower the pressure. I would suggest you get the oil pressure tested at a service centre ASAP. Also have them test the sensor although sensor failure is rare. Low oil pressure will not just go away and causes more damage the more you drive increasing your repair bill considerably.
I'd say you are already in for a cranshaft regrind and oversize bearings. Perhaps (if you're lucky) only just an oil pump although this is unlikely as bearings tend to fail before an oil pump does. I'd replace both at the same time since the engine has to come out for both these repairs. The cost of having the engine out a 2nd time far outweighs the saving on spares when doing both the first time.
