First off what's the brand name and model number?if you have 240 volts to the dryer,and you say you checked all the t-stats and thermal fuse,the only two other things are the motor and the timer or board depending on what model you have,if i were you i would check the t-stats again,more so the ones on the heater,set your meter to 20k ohms with the dryer unplugged go to the part you want to check,pull off at least one of the wires or both if you want,touch the leads one on each side of the part where the wires connect to it,if you see 1 the part is bad or open,if you see anything else but 1 the part is good or closed.if you need more help send the brand name and model number,also there's a belt switch,if the belt breaks the dryer won't run if your model has this check that too,more so if it's an older ge,
sorry did you check the door switch?if the switch is broke the dryer won't start,
SOURCE: clothes dryer
These t'stats are in series with the element monitoring temp's at different locations and are rated for different temperatures. When they are "satisfied", they close the circuit and allow power to the element. When dis-satisfied they "open" the circuit, thereby killing power to the element. If you are reading infinity on one or both of these t'stats when they are room temp, it indicates a failed component and must be replaced. Don't forget to OHM out your element, too. If you read anything other than infinite resistance, it's OK.
SOURCE: how do you test dryer heating element on GEQ9800LW0
Ok maybe the heating element got old and brittle over time and finally
gave up the ghost. But it may not be the element. It could be one of
the safety Hi-limits have blown.READ MORE...
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
SOURCE: Whirlpool Dryer not heating
The motor has to be running for voltage to exit the motor going to the heater. With the back off the dryer and the motor running you should read 220 volts at the heater if all safetys and thermostats are good.
There is a thermal cut out relay on the heat canister. It must read continuity also.
Remember you must remove at least one wire from each component being tested to get a true open or closed reading. If a wire is left connected you get a false reading.
The heating element could be broken and part of the heater wire touching the canister. This would cause a continuity reading and still no heat.
Finally, yes,the centrifugal switch in the motor could be bad and not sending power to the heater on the red wire.
Testimonial: "I did determine it to be the cetrepetal switch..specifically the slide for the weights was heavily gummed up with dryer belt dust. It works now."
SOURCE: Dryer not heating
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
ryur
2-Canister for the heater element.
3-Hi limit thermostat. This thermostat is a
safety thermostat in case the dryer severely overheats. When this safety
thermostat is defective, it should raise a red flag for air flow problems.
4-This is the terminals of the heater element
that is inside the canister.
5-Thermal fuse that controls motor run.
6-Control thermostat. This is the thermostat
that controls the cycling of the heater in high heat mode.
7-Heater for low heat. When you select low
heat, 110V is sent to this heater that the control thermostat sits in. The
heater helps cycle the control thermostat faster, therefore you get less heat
than the high heat mode.
please comment on these solution by saying how helpful.mean vote.
