SOURCE: Wires
yes i have had that same problemo but i used michelle from full houses advice and said no problemo dude. listen to the first guy hes very right
SOURCE: Amplifier wont move subs
I dont know if this will help you but start at the deck and make sure that the outputs(RCA) arent crossed over to highpass and do the same at the amp make sure that its set for lowpass- set half gain -bass boost half gain- subsonic minimum - If that doesnt help try using an i pod with an adaptor that you can play it right into the amp this is to see if you are getting signal from the deck to the amp if it doesnt work with an i pod or mp3 plugged directly into it then you may have got you a blown amp going on- good luck with that
SOURCE: how can i wire 2 alpine type r subs series swr
Hello asg_1024,
The wiring configurations are shown here in the "Wiring Wizard". Wiring 2 4ohm subs in series will result in an 8ohm load.
Hope this helps
SOURCE: what is the best way to wire two alpine SWR 1222D
First off excellent choice on audio equipment, i guarantee you won't be disappointed. So your subs are dual coil 2 ohms. So wire each individual sub in series. If you don't know what this means i'll explain. On each sub there are 2 sets of wire terminals. Connect a wire from the one set's - to the other set's +. Do this on both subs and you will have the coils wired in series making each sub 4ohms. Now to hook the subs together you'll need to wire them in parallel. Now since you have your coils in series, on each sub you have one + terminal and one - terminal left. So run a wire from the + terminal remaining on each sub, and run them to your amp. Splice the ends of the two wires together and plug them into the + speaker output of the amp. Connect the two negatives in the same way and plug them into the - port on the amp. You will now have your amp running at its desired 2ohms. When wiring this disconnect the fuse on your amp power wire to avoid short problems. And if you get confused at all, and aren't sure what to do, ask again don't guess, if its done wrong you could severely damage your equipment. Hope this helped, enjoy the bass...
Testimonial: "very helpful"
SOURCE: have a 2000 gmc sierra ext cab pickup and two type
it depends on the amp what can it handle. will it do 2 4 or 8 ohm is it 1 ohm stable are the subs dual 2 ohms or dual 4 ohms. 1042s are dual 4 ohm subs so if you wire them both in paralel it will drop both subs into a 2 ohm load for each sub that is pos of one coil to pos of sec coil then pos to pos on amp and same with neg to neg to neg on amp. now if your amp is 1 ohm stable i would do both subs the same way you will get the most power out of the amp. but itll run a littl hot if you dont have adaquate power running to the amp. now i wanna think your alpine amp maybe only 4 ohm stable. i would run both subs like i had said pos to pos then neg to neg now both subs will be a 2 ohm load so what you do to bring it back up to 4 is you run the 2 bridged subs into a series which is pos from one sub to neg of the other sub the remaining pos and neg will run to the amps pos and neg. which will make it into a 4 ohm load. now the last scenereo is your amp is 4 ohm or 2 ohm stable. this is how to wire it to 2 ohms and not 1. take one sub go pos to neg then pos to pos on amp and neg to neg on amp this will make an 8 ohm load with one sub take other sub and do the same neg to pos on sub then pos to pos on amp and neg to neg on amp this will tell amp to run a 2 ohm load. 2 ohms is a good run for these subs if the amp can handle a 2 ohm load. now if you would have given the amp model number i could have looked it up to just give you what you needed but with this short info i gave all possibilities.
Some specifications on this link - I haven't found a factory manual in searching on the internet.
http://www.carfixin.com/downloads.asp?sr...
Possibly members only link:
https://www.google.com/url?sa=t&rct=j&q=...
