Check this web site not sure if this matches tv maybe contact site owner and ask ?
https://www.remotecontrolwarehouse.com.au/conia-c21//replacement-conia-remote-control-ce2401fhd-cl3201hdr-cl3201hdvdr-ce2201fhdvdr-dvdcombo-led-tv
Are you sure on the model number ?
is it a led or lcd tv or CRT the closest model I have found is CL03201 which look to be an un=smart
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
SOURCE: Emerson tv remote code
I have ask some help from our friends and they also have problems regarding this type of TV... But try this one
Quotes from friends:
1. "The universal remote that came with my Motorola HD cable box worked fine"
2. chat sessions
3. Chat session find jcut92
My quote:
Ask the vendor for a code, if they don't give you return the TV , it lacks technical support... Believe me or else face more problems in the days to come.
I'm sorry, there's lo luck... Fixya me instead...
SOURCE: conia tv remote codes
I have a Conia LCD TV and the remote died, I purchsed a universal remote and without the codes even on search modes could not get it to find the t.v. I found theat DJ Electronics sell replacement Conia TV remotes online. So if you just need areplcement remote, know your TV model number and you can just replce your old remote.
use a scart lead connected between your digital receiver to your tv
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
