FIXYA Folks need a Make & Model # to assist you.
I should hope the reason is a loose or slipping belt.
Because the belts are never where you can see them, you will not know their condition until they break, or in a few cases, they squeal.
The belt is by far the most common cause of squealing.
God bless your efforts.
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal
occurs due to belt slippage. I would check your belts (look for cracks.
Check the belt tension as well, most washers have an adjustment,
normally on the motor that allows you to increase the tension of the
belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
SOURCE: washing machine makes squealing noise during the
when belt was changed did you find the old belt to be oiley . it maybe leaking oil from trans . and the belt will keep failing till oil leak is corrected.. mm
SOURCE: Washing machine makes noisy squeal when pumping out water
i turn the dryer on it goes for a few minuts and then it fuses all the power points
SOURCE: washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Hi Anthony Mireles, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What make and model number is it>
