Ovens Logo
J
Judy Young Posted on Feb 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I use the self cleaning option on my Kenmore stove model# 970C623331. Do I remove oven racks?
Sal De
Level 3:
  • Kenmore Master 2,699 Answers
  • Posted on Feb 27, 2018
Sal  De
Kenmore Master
Level 3:
Answers
2699
Questions
0
Helped
1003283
Points
8029
That model doesn't come up,that could be the serial number,do you know that when the dryer is in self clean it gets up to 1000 degrees,when it gets this hot it can do damage to the electronics in the oven,from what i've seen on other peoples ovens i will never use the self clean again,but to answer your question remove the racks and clean them in the sink or you can soak them in the tub,whatever is easier for you.i get in there with an sos and scrub,if any spills are big on the floor i wet it and let it sit for a minute or two and scrape it out with a putty knife or you can use a spatula,if it's really bad easy off is made safe for most self clean ovens now,don't put tin foil on the oven floor when you cook,it can damage the floor,so watch out for that.kenmore doesn't make anything so you need the model number to see who made the stove,if you open the drawer under the oven door,look on the left or right side of the frame and you'll see a tag with the model and serial numbers,go here,put your model number in and you can look up the manual for your stove.hope this helps you out.
https://www.searspartsdirect.com/model/search.html?q=970C623331
vince
Level 3:
  • Kenmore Master 2,530 Answers
 vince
Kenmore Master
Level 3:
Answers
2530
Questions
0
Helped
748996
Points
8845
Yes remove them and clean up as much gunk as you can before starting the clean cycle.
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Dec 29, 2007
SOURCE: kenmore stove
try pushing stop clear
Anonymous
  • 8 Answers
  • Posted on Oct 11, 2008
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Anonymous
  • Posted on Dec 09, 2008
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Anonymous
  • Posted on Feb 21, 2009
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Alan Chouinard
  • 52 Answers
  • Posted on Oct 10, 2009
SOURCE: I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
2answers
How do i turn on the self clean? i punched clean and it told me to take the racks out. i removed the racks, but it keeps telling me to remove them and will not do anything else?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
1helpful
2answers
My oven racks don't fit after self cleaning the racks are to narrow or oven is too wide now
No.... the heat warped the sides of the oven and wrecked it......you try and beat the sides back out.... either way you have a junker now....
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 12, 2010 • Ovens
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    There is an E1 F5 code appearing when I set the self cleaning button. I need your assitance. I have a Kenmore electrice self cleaning stove and it was in the house when I bought it six years ago. .
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    HOW TO USE THE SELF CLEAN FUNCTION ON A KENMORE FREE STANDING GAS STOVE
    Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
    heatman101
    " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
    2answers
    Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
    heatman101
    " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Apr 13, 2010 • Ovens
    I have locked my Kenmore self cleaning stove, now it won't open
    Sorry you gave the sereial # for the oven. Need model #. Here is an manual that might work for you. cout and past in address bar.
    http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
    Or you can go to this web sight and look up your oven.
    http://www.managemyhome.com/mmh/answers/Answers.action#l4q106688
    Good Luck
    New fridgidaire self cleaning oven w/ no insturction manual
    its a new oven?? press the clean button the arrow up(the display should read 3:00, press start,the door will automatically lock and your on your way. remember to remove racks first, they will warp and discolor
    Feb 24, 2008 • Ovens
    Top Kenmore Ovens Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
