Based on the information you've provided, there are a few possibilities for what could be causing the issues with your Toro Dingo:
Engine damage: Running the engine with very low oil can cause serious damage to the engine, including wear on bearings and pistons. This can result in a loss of power and difficulty starting. If the engine is damaged, it may need to be rebuilt or replaced.
Hydraulic system issues: The low hydraulic oil level and small hose leak could be causing issues with the performance of the trencher attachment and other hydraulic functions on the machine. It's possible that the hydraulic pump is not getting enough oil, which could cause a loss of power.
Fuel system issues: If the machine was running on low fuel, it's possible that debris from the fuel tank could have entered the fuel lines and clogged the fuel filter or injectors. This could cause the machine to stall or run poorly.
Given the symptoms you've described, it's difficult to determine the exact cause of the problem without further diagnostic testing. If you're not able to perform a compression check or other diagnostic tests yourself, it may be best to take the machine to a qualified mechanic who can perform a thorough inspection and provide an accurate diagnosis. They can also perform any necessary repairs to get the machine running smoothly again.
sounds like your hydraulic motor maybe acting up. you need to check your hydraulic oil flow rate. if you don't have the tools you would have to take it in it is a fairly big job
Direct from the Toro/Lawn Boy data sheet is this information for the hydraulic oil. They state to use
AW Hydraulic Oil, biodegradeable, Mobil EAL224H. Here is a copy of the data sheet.
