We have discovered a few more sites like netflix that allow you to watch new movies and TV Shows for free: https://codetounlock.org/best-apps-like-netflix/
1. You may not have the TV set to the correct input.
2. Rather than mirroring, there's a chance you turned the TV into an extended display, meaning it's like a second phone screen. Try moving things from the phone to the TV screen by nudging them against the side of the phone screen. (This is unlikely though)
SOURCE: my samsung phone is showing only a blank screen
well mayber the flex(ribbon) connecting your lcd to the board is damaged try replacin it with a new one.
SOURCE: I have a samsung smart tv and a samsung galaxy s
Reset your TV.
With the power off - use the remote and push mute + 1 + 8 + 2 + power button.
When the set turns on, you will see a menu pop up. Just hit enter on the remote and you will see Factory reset. Hit enter again and the TV will reset.
if it is in warranty,,,,,,,claim it ......
.do tell me
SOURCE: Can I mirror a kindle del fire on a Samsung smart tv?
goto the link below
https://www.youtube.com/watch?v=GbmFLYFQQIE
SOURCE: My TV has black screen after trying to watch my recorded show. How can I get my tv back?
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
