Question about Maytag Dryers
How do you replace one of the DRUM-LIFTERS Part number PS2037217 on a Maytag Model #MAH8700AWW. My question is how to access the screw that holds the lifter in place after you slide/snap it in.
  • Maytag Master
  • 2,699 Answers
Http://homeguides.sfgate.com/replace-broken-baffles-frontloading-washing-machine-104577.html
Posted on Feb 28, 2018
  • Sal De Feb 28, 2018
    most baffles don't have screws,they just clip into place,when you pop the baffle in place if it feels tight i wouldn't worry about the screw,but just follow those instructions,remove the top of washer,remove the hose on the top of tub,and this is how you get at the screws.hope this helps you out.
Anonymous
SOURCE:
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: Baffle came loose from drum...how do I
there are 3 Tork screrws on the back panel that will allow for you to slide the top back and get access to the top of the drum
Posted on Jun 01, 2008
Anonymous
SOURCE: maytag neptune mah8700aww/drum gasket removal/replacement
The bottom of my gasket was torn open all along the bottom. I ordered the gasket but I wanted to see if I could repair it so we could catch up on the wash. I bought some rubber contact cement that cost me under $4.00. I Glued the gasket rubber together by overlapping the the seem a little. Still had a hole in one spot. I had a sheet of rubber around my shop that was about 1/16 of an inch thick and cut it about three inches wide.. I used a little sandpaper to rough it up a little. I cut it in two.
You have to apply contact cement to the gasket and the rubber you are applying it to. ( I dry fit it first to make sure it would fit). Just to make sure it would hold I also glued rubber to the outside bottom of the gasket to reinforce the glued seam. . You need to take off the front panel to do this and there are directions to do this if you search for it. I was able to run the washer in about an hour after the repair.
If your washer is in the basement and are not afraid of getting the floor wet give it a try. I have run the machine with heavy loads for two days and no leaks. I feel confident that the repair will last for a long time. A cheap fast fix. It took me about forty five minutes. Make sure you unplug the machine to do this. Good luck.
Posted on Jun 24, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Need to replace the screws that holds the drum baffle in place
remove the scresw holding the door on, remove the door, the remove the 2 screws oppisite th edoor inge and the front panel will lift off. there will be 2 5/16 screws holding the top down to the frame of unit, the top will then lift up[ giving you acces to the outside of the drum to resecure the drum baffle
Posted on Nov 21, 2008
Anonymous
SOURCE: I have a Hotpoint AQXXF149PM washing machine, and
I have exactly the same problem on my ...129 model. I'm a mechanical engineer and looking at the design it apears that these aren't designed to be replaced. The 90 degree tab looks to be only accessed from the outside of the drum so can only lock the tumbler in place from the factory. It needs to be bent flat to get the paddle on!
I hope someone can prove me wrong??
Posted on Jul 31, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: How do you replace one of the DRUM-LIFTERS Part
Here is a video on replacing the typical lifter
CLICK HERE
However - it appears in the parts breakdown HERE that this machine's lifters are held in place with a screw on the opposite side of the drum!
(#20 & #15)
This is not an easy DIY project - as the top must be lifter in order to access the opposite side of the drum and replace the lifter (aka drum baffle)
CLICK HERE
Look for the service manual behind the kick panel of the unit. There should be a reference in it on accessing the drum and changing the baffle.
SERVICE MANUAL PDF LINK
TECH MANUAL PDF LINK
Thanks
Posted on Mar 03, 2011
Maytag MAH8700AWW noisy. Bearing?
In some cases it is a simple adjustment of the Levelers. Use a flat level device to check the levels from front to back and side to side. Make certain the Washer and Dryer have a space between them and they do not bang into one another.
Mar 17, 2014 | Maytag Neptune Washing Machines
How do you take the front off to acess the door switch?
Click this link http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MAH8700AWW/3048/0153200?searchedModel= MAH8700A&blt=
This is the schematic for your entire machine. You would first remove the top panel by unscrewing the screws that hold the panel to the cabinet on the back of the machine. You would next slide the top panel towards the rear of the machine and remove the top panel from the machine. You would next unscrew the screws holding the control in place and remove the control as well. After you remove the control you would next remove the screws holding the from panel to the cabinets frame. Open the door and there are a couple screws to unscrew on the same panel where the door seats. Some do also remove the door as well due to awkwardness and weight issues. You would then remove the rubber boots attaching retaining ring using a flat screwdriver to pry over the ring over the front panel lip. Unseat the rubber boot termed as bellows and move the front panel diagnonally towards you. You can then access the door switch assembly and replace the assembly. When putting the unit back together install the front panel screws and the screws along the inside of the door before seating the bellows and the retaining ring. The retaining ring is the most difficult part of this job and reseating the ring and the bellows is the most difficult of this job and may require an extra set of hands to hold the ring on one side while using a screwdriver or putty knife to work the ring back on to its properly seated position. If you have any further questions message me back.
I await your reply
Thank you,
Rick
Jan 09, 2012 | Maytag MAH8700A Front Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
Apr 15, 2010 | Maytag SDG4606A Gas Dryer
How do I access the drum to tighten the dryer fins
Disconnect power to the dryer !!! Remove the 2 screws holding the door hinges on and remove the 2 screws opposite the door hinges . This will let you pull the top of the front panel outward and lift off the bottom clips . If you have enough room , slide your arm thru the front opening to tighten the screws . Otherwise , remove the 2 screws holding the clips for the top , 1 on each side , and lift the top , to get better access to the screws .
Apr 10, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
I know that I am asking this for the third time; however, on the other two I forgot to notate the make and model. Again, after I opened the top of the dryer, there were no coins, it seems to be the screws...
If the screws holding the baffles just came out of the baffles or if the baffle broke they can be reinstalled. If the screws have ripped though the drum, the drum will need to be replaced. The screw part number is 33002973. The short baffle part number is 33001755. The tall baffle part number is 33002032. If you need the complete drum it is part number 33001889. Below are the instructions on how to replace the drum. Parts can be ordered from this link.
below is a link to the service manual for the info u need to take aprt or replace the dryer drum on a Maytag Neptune, I suggest u print it and then enlarge it if u can read it.
http://media.fotki.com/1_p,swdbrqkqdgssrtkxgtqsskgwtqkq,vi/stkwfgbrgxkgtddqfqs/1/1303472/5961857/image7951020310251998097img-or.gif
Apr 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune front load washer, model MAH8700AWW, 4-5 years old. At ant low or high speed spin cycle, the drum bangs badly regardless of load size. Why & what can be done to fix this?
Your bearing are broken or wearing out.
Replace the bearings.
This requires taking the whole machine apart and requires special tools.
I would call a appliance repair company in your area.
It can be very expensive to fix.
Maytag machines are not my favorite.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
Maytag Front load washerMAH8700AWW.
I have a maytag mah7800 also / great machine . never had a problem yet . if you remove the screws in the back holding the top you can lift it off . inside you wil find the tec sheet . on the side in a plastic sleeve . in it is the code . it will also tell you what to do ,. mm hope this helped . let us know mm
Dec 12, 2009 | Maytag Neptune Washer
Nov 21, 2008 | Maytag Dryers
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
329 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
