You likely need to add an antenna amplifier. The PS3 should have been hooked up to one of the other source inputs other than the antenna. If it was attached via the antenna, a solder connection may have come loose or the coax got kinked.
If no sound and closed captions (writing) appear in the menu look for (it may also be found in the box menu for cable box) captions and either turn it off or select a different choice.
Most sets (not the cable box) will offer captions all the time or only when sound is muted.
SOURCE: My sansui model SY-20-EYE Front panel lock plz
http://tv.manualsonline.com/manuals/mfg/sansui_electric/hdlcd1900.html
Try the above link to download the user manual in PDF. It has all details.
Gopakumar Gopalan Google
Make sure the TV can receive digital over the air signals (it should have an ATSC tuner), that is it doesn't need a digital converter box. In the menu settings make sure the TV is set to antenna, not cable. You should be able to use the auto-scan (auto-program, etc.) from the menu to find and program the local channels.
