From tomshardware site,,,
You just switch off the power while the "Checking NVRAM" is
dispalyed and the next time you boot, the BIOS is reset.
The easiest way to test it, is to first disable the "Full screen
logo" in
"Boot settings configuration" and then do the test. If the BIOS is
reset,
the Full screen logo is displayed at boot time.
see if that works
SOURCE: Toshiba Tecra M4 Bios Password Reset
there are two way
open take cmos you will see one littile batry in you laptop when you open take that battery out for mint then put back in
secound way is
jummer setting
SOURCE: How to reset bios password
The FSC 1320D's are truely remarkable... We haev had a default BIOS password for our laptops for a while now, but it has recently started to have been guessed or found out. So of course, they needed to be changed. And suprisingly enough, the FSC 1320D will not allow you to reset the BIOS password through ANY user method so far, and we really have tried everything.
Removing the BIOS battery - This does nothing, at the best of times the system will display an error saying it has been removed but other than that the BIOS password remains.
Updating the BIOS - Most people would suspect that if you update the BIOS it compeltely refreshes the set system settings, including the BIOS password. This again, is not the case with this model, as every attempt at updating the BIOS so far has been deemed useless.
BIOS Corruption - This again, does not work. It leaves the system in a dead state, usually the BIOS resets. This has occured once, as during boot we noticed the options to scan memory had changed and it took longer, but the BIOS password remained.
Backdoor Passwords - Again, do not work. We have tried the entire list submitted by Ekse.
Reset VIA Software - There are some hacking programs out there which reset the BIOS through the Operating System. And i think we can all guess what im about to say... They don't work. It may just be for this model, as i've not tried them on others, but the BIOS password for the FSC 1320D does not get reset using this applications.
So, the verdict?
Apparently you can submit your laptop back to Fujitsu Siemens for an 'Out of warranty repair', and they will reset it for you. Assumingly by changing the BIOS chip completely. The only downside to this is that it can cost anything from £50 - £150 depending on service charges and delivery costs. My opinion, wasting time on a laptop that is past its sell-by date like the FSC 1320D is really not something you want to be doing. Buy a new laptop and sell the 1320D for spare parts.
SOURCE: reset bios password
try to remove the cmos battery from the motherboard and insert again...it will reset ur bios password...
SOURCE: how to bios reset jumper location dell c400
try to remove the cover of your laptop. Then remove the motherboard battery for about 10 min. Put it again and bios should be restarted.
Most laptops do not have one and clearing the cmos will not help.
Contact HP, they have a master password that can get you in. You may have to fax them proof of ownership to get them to help. I had to do this on a laptop.
Hope this helps
use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine.
Hope this helps
