Question about The Office Equipment & Supplies
Why will the ribbon not go back down into position so I'm not typing blank letters but when I use correction button it types the letter
  • 482 Answers
Make and model will be helpfull
Posted on Mar 02, 2018
6ya staff
SOURCE:
Anonymous
  • 19 Answers
SOURCE: Wrong letters typing
it sounds like you were using a non-brother correction tape,one that was too sticky and consequently too "slow" and during the correction sequence the fingers of the daisy-wheel got entangled with the tape. Make sure that the correction tape is of a "non-sticky" nature and then take off the correction and printing tapes. That way you will see better how the daisy-wheel is fitted . I will assume that you have an instruction book to show how this is done. before fitting the daisy wheel examine the fingers to see that none are bent or crossed over each other. If this is the case it is better to buy another one. bring your typewriter to the shop if this is the case and they will possibly re-fit the wheel for you. good luck.....
Posted on Mar 21, 2008
Anonymous
SOURCE: scrambled letters
if it is an acer press fn and f7 that should fix it
Posted on Oct 25, 2008
JSEhandyman
Jon Stignani
  • 368 Answers
SOURCE: keyboard letters are typing different letters
Hi Melaine,
It sounds like you're in a word-processing or text-editing application, and have selected a Symbol font. Change to another font (like Arial) and it should clear-up.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Posted on Apr 04, 2009
M2Tech1
Andy Bell
  • 313 Answers
SOURCE: Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Posted on Jun 12, 2009
benwabnick
Ben Wabnick
  • 2404 Answers
SOURCE: my dell lattiude keyboard doesnt type correct letters type j and
Go into safe mode and see if the same things happens there, if it does then bring it back into normal windows and go into notepad.
move your fingers across all the keys from left to right on each row. If the keys still aren't typing right then the keyboard needs to be replaced.
Posted on Jun 29, 2009
Typewriter is only typing the top half of each letter- changed ribbon- still doesn't type the bottom of the letters ???
typing the top half of each letter Donna, sounds like the carriage spool is stuck or out of adjustment. Not to hard, but pick up typewriter and slam it down on counter to see if it put carriage and spool back in position.
Good luck.
Mar 31, 2016 | IBM Wheelwriter 30 Series II Typewriter
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
Is there an auto correction feature
The key to the right of the spacebar with the "X" printed on it is the correction button. You just place the carrier on the character to the right of the wrong one and hit the corr. button. The carrier should automatically back up and and remove the incorrect character and if you hold the key down it will continue to back up and remove characters. then you just type in the right one(s). Of course you have to have good "correctable" ribbon and correction tape cartridges installed. If the tapes are old you may have to advance them by typing and correcting or by manually advancing them before they will work. If the correction doesn't remove all the ink from the paper you may have a bad ribbon and/or correction tape.
Sep 17, 2015 | IBM Wheelwriter 3500 By Lexmark Electric...
Ibm wheelwriter 6 manual
On the right side of the printer is a black gear about 2" in diameter with the T/W off you should be able to move it easily, if you can't wiggle it back and fourth with some force and it should free up.
DickyO
Jul 10, 2013 | Office Equipment & Supplies
When typing wrong letters and numbers type
You might have a "proportional space" printwheel but the pitch selector is on 10, 12, or 15 instead of PS. OR it is on PS but you have a normal print wheel. Try selecting different pitches. Another thing that causes that problem is sometimes the ribbon or correction tape gets caught in the printwheel.
Feb 18, 2010 | Swintec 7040 Typewriter
Jun 11, 2009 | Brother ML-300 Typewriter
When typing does not print whole letter or doesn't print at all.
it would help if i knew exactly what model # we are talking about. but try this. look closely at your ribbon film after you type some characters. are the letters overlapping themselves? if so, press and hold the "code" key down while pressing the period key. let up and try typing. if that doesn't help, write back with model # and maybe i can assist further.
razors
Mar 30, 2009 | Swintec Office Equipment & Supplies
Brother ML300 Typewriter
make sure the correction tape and ribbon are in properly between the metal fingers and the card holder. turn machine on and off. if it still doesn't work it needs professional help
Oct 22, 2008 | Brother ML-300 Typewriter
Correction function not working
Make sure the ribbon is a correctable (yellow or orange core) not a multi strick (blue core)
Sep 13, 2007 | Brother GX-6750 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
47 people viewed this question
Top The Office Equipment & Supplies Experts
Thomas F. Schneider
Keith Love
James Cagle
James Cagle
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
