Computers & Internet Logo
R
Russell Sheikh Posted on Mar 01, 2018
I have some LG v20 that originally was rooted to unlock I guess. But after factory reset The screen only boot up to "Team Win Recovery Project" and can you guys restore the filmware correctly?
5 Related Answers
krihard
krishna Singh
  • 407 Answers
  • Posted on Feb 09, 2008
SOURCE: recovery disks
go to download .com recovery download it.
Ved Pradhan
  • 54 Answers
  • Posted on Feb 26, 2009
SOURCE: Restore factory Settings on a Dell Inspiron
hi..
if you have windows xp then you need to turn your computer as soon as you do that before you see the windows xp logo hold down the control key and keep tapping f11 key.it should take you to the screen fro factory settings and if it is windows vista then you can go ahead and press f8 and then choose repair my computer,hit enter which will then prompt you to login in once you log in it will tell you to choose the options from the options listed below choose the one which says restore factory default...you computer will be restored to factory settings..
vedhick
Anonymous
  • 64 Answers
  • Posted on Aug 13, 2009
SOURCE: restore to original factory settings and no CD's
http://www.restoredisks.com
Anonymous
  • 497 Answers
  • Posted on Apr 23, 2010
SOURCE: WANT TO RESTORE ACER ASPIRE 4520 TO ORIGINAL
Hello, If your system is capable of doing a Recovery via Hidden Partition on Hard Drive, you can access it by Pressing Alt + F10 and choose Recovery Option.
anilbr
Balakrishnan Computers (A Computer Repair Shop)
  • 468 Answers
  • Posted on May 29, 2010
SOURCE: restore acer aspire to factory setting
For all Acer Netbooks try to initiate the recovery using Altgr key (righthand side of the space bar) and F10, ie Altgr+F10 as soon as the computer restarts. If the recovery partion is corrupted or do not have the CD. Try the below steps:
No Restore CD / eRecovery / password / ALT + F10 or F10
1 - Recovery of data on the hidden partition PQSERVICE for password
A - Installing the software R-Drive Image to create an image of this partition (this file has the extension. ARC)
B - Always with this software, create a virtual disk logic to see the files
C - From the desktop, go to the newly created virtual disk and find the file aimdrs.dat. The open with the notepad and get the password.
2 - Reactivating the ALT + F10
A - Always on the virtual disk created, find 2 files: mbrwrwin.exe and rtmbr.bin.
B - Copy these 2 files on drive C: \
C - Since the MS-DOS (Pocket PC) to C: \, type the following command: mbrwrwin install rtmbr.bin
D - The function has been reactivated.
3 - Start of Restoration
A - At the start of the PC, go to the set-up to check if the function is well on D2D enabled (normally it is a default setting ... but hey you never know.)
B - Once the audit and that the PC has restarted once the ACER logo appears, simultaneously press ALT + F10 to start the restore utility.
C - When it asks for the password, you need to type one found in the file aimdrs.dat. CAUTION: The keyboard is QWERTY mode so we thought enter his password, but as some letters are reversed, it does not work.
4 - Normally at this stage there ... everything works and restoration is smooth.
Note: If the operating system does not work, it is possible to do this from another PC by connecting the hard drive or USB slave
Need operating system for my viewsonic g tablet 300-2.2
Angela,
Your Viewsonic (apparently) used: Android OS 2.2 and that is quite old!
(Almost always), a Android device needs to be OPERATIONAL before it can be updated. It MUST also be able to 'communicate' to receive the updated OS...
Now your VS (apparently) HAS a external SD Card slot, so you MAY be able to copy the new Android OS to that card then maybe you can load from there ~ BUT, your Tablet MUST be operational to do it!
Anthony
I'm trying to jailbreak my SGH-1747 but every time I go to towering it says my phone isn't supported. How do I fix?
H Derek. The i747 is a gaalxy S3, if I'm not wrong.
OK, when you post the qeustion sking that you need help to jailbreak an Android device, believe me, you will hardly get help from the community. This will send a message to the Androids fan that it must be your first time trying to root an Android device.
I will leave a link here for you to read which it will explain step by step on how to root your device with Kingroot. A another one with everything from root to flashing and customizing.
http://forums.androidcentral.com/t-galaxy-s-iii-rooting-rom-s-hack-s/466427-guide-how-root-t-galaxy-s3-sgh-i747-m-kingo-android-root.html
http://galaxys3root.com/category/galaxy-s3-root/
Nov 25, 2015 • Cell Phones
Como puedo desbloquear una Tablet pc7518A
translated to English is:
As I can unlock a Tablet pc7518A
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen. Select wipe data / factory reset with the volume keys and tap the Power button to activate it. Select Yes - erase all user data with the volume buttons and tap Power.
How to unlock an Android phone tablet
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
My lg viper 4g lte wont boot completely
if you wont mind losing your data that are not backup... you can simply perform a hard reset to factory settings. 1. remove the battery 2. re-instert the battery 3. hold VolumeDown button then press the power button Do not release the volumedown key til u get to recovery mode Now that you are in recovery mode, first try WIPING CACHE and then reboot your phone. if the problem persist, then repeat step1-3 again this time, select WIPE DATA FACTORY RESET if wiping cache solves it, then your data are intact WIPING DATA FACTORY RESET wil return ur phone to new without losing any unlocking feautures. i'm McKennie
www.iswaltech.com
www.iswalhost.com
3answers
How to get recover deleated pictures from your phone
Try Data Recovery Software!
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% safe
2answers
The pandigital ereader just boot to login screen but won't boot up the system
you should be able recover it. most phones and tablets you hold the power and volume up button when turning it on to reach the recovery menu. there should be a restore option. if there's no back ups do a factory reset. if you can't get to a recovery menu you can always Google how to root it and install a custom system 7_20_2013_12_37_59_am.png
1helpful
2answers
3helpful
Reformat my samsung v20 back to factory conditions
You pc has a hidden recovery partition. You need to press F11 at boot up to launch recovery. But before you do make sure to back up all your data. the recovery wizzard will walk you though the whole process.
Good Luck
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
