Greetings
Check to make sure their is nothing stuck up top between the inner and outer tub.
If it is spinning but not fast enough..you need new clutch..of coarse this only pertains to non- electronic machines these have a start button you push...the one im talking about has the knob and dial you turn and set by pulling out knob...
Odds are your pump is bad. Check to see if it's leaking under the washer. If it's spinning & still has water left in the drum..You need a new pump.
SOURCE: final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
SOURCE: GE Washer spin cycle not working
If your washer pumps out the water but doesn't spin, check these:
if this helps please vote me a fix ya
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust? The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles. Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around. Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load. That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
SOURCE: washer stops during spin cycle
i just relaced my door switch to my washer and it fixed my problem.my washer was doing the same thing as yours
SOURCE: ESTATE TAWS800JQ1 WILL NOT SPIN
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
