SOURCE: programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
SOURCE: scanner codes for uniden bearcat scanner
phatgirlz, hi, are you looking for freq numbers for your area of Illinois? If so, go here, and click on your county.
http://www.radioreference.com/apps/db/?stid=17
If your looking for 10 codes and other police lingo, go here;
http://www.bearcat1.com/radioil.htm
Hope this helps you out in your search,, let us know. Mechanic
SOURCE: need codes to program my police scanner
here is a few sites that can head you in the right direction.www.radio reference.com,www.scannermaster.com,www.bearcat1.com.hope these help
SOURCE: how to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
