SOURCE: wont finish washing cycle
suspect not draining. if not then problem could be the filter. at back, remove the small panel at the bottom. you will see a hose from the bottom of the tub to the pump. remove this hose at the tub end and the filter is inside.be carefull, if machine has not drained, a lot of water will come out. disconnect from mains of course
SOURCE: GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine.
If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch
If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly
Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor
Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
SOURCE: wash machine is displaying LD and not finishing
Hello there:
Ld means long drain
meaning that it takes more than 5 minutes to drain the tub
If you press the cancel button this will clear the code or just unplug for 10 minutes
BUT if it is taking this long to drain this means that the drain pump may be getting clogged in this case you will want to open the machine and inspect the drain hose and any filters that are connected to it and also you may have to remove the drain pump and clean out ok
Continuing to operate the machine in this condition will lead to bigger problems so it is best to take care of it now ok
I hope this is very helpful for you
Best regards Michael
HI HAVE YOUR PUMP FILTER CHECKED IF OK CHECK HEATING ELEMENT ..SEE IF ITS IN CIRCUIT.. THATS WHAT NORM HAPPENS IF THESE ARE NOT HAPPY.BET OF LUCK.
MARK 07779933829
