SOURCE: digi box picture and sound out of synch
you more than likely have a bad box from cable company easiest fix is to unplug then plug back in. The technicality is that your box is loosing data packets due to noise(electrical interference) which can originate in your home or possible someone in your nieghborhood
SOURCE: Goodman Evaporator fan runs continuosly
first disconnect the green stat wire wire could be bad if still runs change the board on the indoor unit pull board and take to goodman store with model number and serial number its under warrenty they will give new one hope this helps also look at dip switches and instructions to make sure ok
SOURCE: How do I retune my goodmans television for
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
SOURCE: panasonic digibox tu-ct20 has all stations mixed
Just had the same problem with a Panasonic digibox whilst trying to fix a customers tv. The only way I can see to unmix them is to use Profile menu to create a new Profile and manually add the channels one-by-one to the new profile, or replace the digibox. I suggested to the customer best solution - replace digibox as they are cheap enough now.
SOURCE: How to connect total control urc 11-2910R00 to Goodmans GDB3 free to view digital tv reciever
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
