SOURCE: Sheet caught under agitator
the agitator comes out..... by simply taking off the cup that holds fabric softner, just pull upward if needed wiggle and pull. under that you will see a raised plastic piece the raised plastic pc is pulled of by using a pliers pull upward under this you will find a bolt 1/2 or 9/16 socket remove bolt and pull out agitator same way by wiggling and pulling upward
SOURCE: removing agitator
Sorry, I can't help you. This is the area for asking questions about computer monitors, not washing machines. You clicked the wrong link.
Look at the top of the page, click the Westinghouse link and then on washing machine. Enter your question there.
SOURCE: Kenmore Washer 70 Series - sheets stuck around agitator
The transmission probably stripped the worm gear that drives the drum - you would have to crack it open and take a peek.
SOURCE: Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
SOURCE: Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
