Wrong that mobo is not blue and is not made by intel.com at all
it is ASUS..com
says so on the mobo
and at their web sets all mobo sold by them from 1995 to
2022, have QVL LIST ON CPU, ALL DO THERE.
SO FIND IT OR ASK THEM.
TOOK ME 3 SECONDS TO FIND THIS GOOGLE
https://www.asus.com/us/SupportOnly/P5S-MX%20SE/HelpDesk_CPU/
QVL = QUALIFIED VENDOR LISTS, RAM OR CPU
FROM 1995 TO NOW, AND ASUS.IS THE BEST DYI MOBO MAKER BAR NONE, AND GIGABYTES TOO. 2ND FIDDLE.
SOURCE: Upgrade
hello,
Please see documentation of the motherboard. if there is available ugrade of the processor, im sure the Ram can be upgraded upto 2Gig or higher but im not sure about the processor.
Anyway i recommend you to refer to you motherboard manual.
hope this help. melnavz
SOURCE: asus p5s-mx se motherboard
The unit goes in a spare 5 11/2" drive bay, same type as your DVD player/writer; it is held in place with screws provided.
The audio cable connects to the 'front panel audio pinout' on your motherboard or if it is a plug there should be a backside slot cover provided that has a hole in it. You pass the plug through this hole and plug it into your audio ports, the green hole.
The1394 cable is called Firewire and connects to the firewire pinout on your motherboard.
The USB cable connects to an unused USB pinout on your motherboard.
Do you need a map of your motherboard that shows where these are? They are labeled clearly. If you have never had your hands in a PC to connect things to your motherboard LET ME KNOW and I'll advise you on how to do this safely so you don't damage anything or yourself.
If you have any other questions I didn't cover JUST ASK ME by commenting below and I'll get back to you as soon as I can.
Regards,
Worldvet
SOURCE: do you have a audio driver of foxconn a719l built-in sound drive
follow the link for the audio driver.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5S-MX%20SE
Let me know if it helps.
Mark
SOURCE: Intel Processor Benchmark
I cant find a benchmark but virtually any core 2 duo wipes the floor with a pentium d processor. The pentium d line of cpu's was completely replaced by the more powerful core 2 duo line of cpu's
SOURCE: i want to supress the password in the bios motherboard
Newer SONY VAIO LAPTOPS (Core Duo, Dual Core, Core 2 Duo) generates a 16
digit error code like this one: "xxxx-xxxx-xxxx-xxxx" after 3 wrong
password attempt, its an alpha numerical code that can be used to generate a
master password that can UNLOCK all BIOS settings and the Power ON Password
when you turn on The Laptop I just Unlocked My SONY VAIO VGN - AR Model With
this code at http://www.laptoprebirth.com Hope this helps for everyone
