SOURCE: New Rechargable Batteries Die after A Couple of Pictures
This model is renowned for poor battery life. Some people say using the CRV3 battery lasts a lot longer but my advice is to buy NimH batteries with at least 2600mah. Some Nimh are only 700mah and obviously will last less than a third the time of a 2600. Keeping the use of the LCD to a minimum will increase battery life and using the flash puts a tremendous drain on the batteries so if you can do without the flash switch it off. Combine these tips with a set of 2600mah batteries and I'll guarantee you'll be pleasantly surprised. As a sideline I always have a good laugh when I see an Olympics opening at night or a firework display and all you can see is thousands of flashes going off which the majority only reach about 12 feet maximum and the parade being shot is some 300 feet away. BMW
SOURCE: Need specs on AC adapter
It'll need a +5v and a +12v.
I'll repost tomorrow with current ratings, I've got one at work.
Or you could take the drive out of the Seagate case and put it in another case, they are cheap.
SOURCE: going through batteries abnormally quickly
Hi. I had the same problem with my Canon S1 IS. In my case the problem was caused by flash capacitor. To check if it is the case just follow the following procedure. 1. Turn on the camera. 2. Be sure that low battery warning is flashing on LCD. 3. Turn off the flash by pressing flash button (be sure that flash is OFF but not in AUTO regime). 4. Turn off the camera. 5. Open and close the battery door. 6. Turn on the camera. 7. Take several pictures.
If after these operations the low battery warning does not show up it means that flash capacitor causes the problem and it should be replaced. Or you still can make pictures with your camera without using a flash.
SOURCE: CAMERA battery low message with new batteries
I have the same problem with mine!! Had it about 14 months now too!! Glad I'm not the only one... I don't know what to do! I have gotten brand new rechargeable batteries and instead of getting 250 shots, I only get like 20!
SOURCE: My camera eats batteries like candy!
i have similar problems with a Kodak .. i bought the best lithium ion rechargeable batteries. and it still only lasted for about 10 min..
i put them in the charger and the charger lit up green...meaning the batteries are ready and fully charged only took about 15 min.to go green.
i thought that was strange so next time i just let them stay in the charger for like 3 hours....the next time i used my camera i had it taking pictures for over 2 hours..non stop!!! i was so happy..so the dumb charger was incorrect when it says the battery was fully charged..
