SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
SOURCE: Hello -Just looking for help on fixing a service
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
SOURCE: fisher and paykel intuitive eco washing machine
intuitive ECO Model IW811 display error code 49...any one can help me
SOURCE: Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Hi dear
Change yout Out of balance switch which is under the control module and your unit will work perfectly fine.
How do you change OOB switch?
My email is [email protected]. pls advs.
