Call toll free number in the instruction manual at the link below:
https://www.manualslib.com/manual/139884/Reebok-Rx-6200-Rbtl12920.html
Reebok RX 6200 RBTL12920 User Manual
You need to contact the maker of the product.
SOURCE: incline wont work
Check here for the user manual:
http://manualfox.com/link/reebok.htm
And maybe send them a manual request?
SOURCE: Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
SOURCE: My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
