For moulinex maxima delux food processor
To find replacement parts for your specific model of food processor, you can try the following:
Be sure to have the model number of your food processor on hand when searching for replacement parts to ensure that you are purchasing the correct part. Additionally, keep in mind that some manufacturers may not offer replacement parts for older models or may only offer them for a limited time after the product has been discontinued.
SOURCE: Jack's Poer Juicer model #CL0003AP
http://www.schooleyweb.com/sites/jacksjuicer/questions.php
I found this instruction on the web at the above site. Now, I just need to figure out the name of the part and maybe I can order a new one. Hope this helps everyone!
"See the back inside cover of the instruction manual for the spare parts order form or call 1-800-460-6210. You can also e-mail us at [email protected] "
SOURCE: replacement parts
Here is the web site for all of the questions in regards to replacement parts:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3699&secid=53&linkon=category&linkid=91
SOURCE: Bravetti Food Processer
You can get parts from this company.
http://www.euro-pro.com/europro/productdetail.aspx?pid=E50ADA3D-BACA-44E7-9E78-05263C526241(Euro-Pro+Base+Catalog)
You can call them as well
For technical support, please call us
toll-free at 1-800-798-7398. Hours are Monday through Saturday from
9:00am to 6:00pm Eastern Standard Time.
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
SOURCE: replacing a MTD spindle assembly
Yes, most spindles come with non threaded holes. The metal is soft and you can just use regular bolts. Once you start them, they cut their own threads.
Testimonial: "Good, I was afraid I had the wrong part. Thanks for your help!"
Hi Kerri Woods, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Manufacturer and model, please.
Moulinex maxima delux food processor- the removable cylinder that fits over spindle
