SOURCE: message says player error - music is not available?
Your VX8300 can only play .wma files .. so if there's any .mp3 on there it's going to say that. Also, if you recently put on new files try taking them off then trying the card again .. .if that works then one of your new files are corrupt/unreadable
Another thing to try: goto: Get it now .. music n tones....my music ...songs ...options...reinitialize library database. ( Be warned, you may lose some files this way so make sure everything is backed up on your PC)
SOURCE: playback failed message
hi it happens to me aswell if the songs are on your memory card take it out close the music player and put the card back in. if the songs are on the phone turn it off then back on =] hope this helps
SOURCE: cannot play this sound appears
Hi Asbn!!!
Sounds like u have an musicfile problem.
There r some music files that cant work on Cellphones.
One or too easy ways of fixing this is....try to erase the sound from the Phone and memorystick and install it again. That could work but if not, try to fix a new version av that song and install it.
Last solution is....if none of the Above works....try asking in a
Cellphone shop!!
Good Luck :-)
SOURCE: Error Message
You have to synchronize your Sansa to a computer that has a current subscription to Rhapsody, and you have to sync the Sansa to that same computer at least once every 30 days, or the Rhapsody songs will stop working. Use a different music service that is free, or convert all of the songs to Mp3 format to get around the problem. If you get a subscription to another music svc, then you must maintain a current subscription with whatever new svc you choose as well.
