Why can't i play bakery story
First I must ask what platform are you trying to play it on? iPhone? iPad? or MacOS?
The listing on iTunes says it is for iPhone and iPad. So if you are trying to play it on your Mac computer .... no.
Second, If you are trying to get to play on your iPhone or iPad then you need to sync your iPhone/iPad with your computer, but there are a couple things to check.
With your iPhone/iPad connected to your computer via USB cable, if iTunes does not automatically startup then manually startup iTunes. I'm assuming you have iTunes version 11.2.1 or later.
In the left-hand column of iTunes, under the 'Library' heading you should see 'Apps' .... click on it. In that screen you should see Bakery Story listed. If not, then Bakery Story has not been downloaded to iTunes yet and you need to try the download again.
If Bakery Story IS showing up there, you now want to look under 'Devices' and click on the name of your iPhone/iPad. Now click on "Apps" in that window and you should see a list of the apps that are actually installed on your phone/pad. If you see Bakery Story in that list then Bakery Story HAS been successfully installed. But, if as you claim, Bakery Story is not listed there you need to check in the bottom-left of that list and see if "Automatically Install New Apps" is checked. If not, click the box tout a checkmark there, then in the bottom-right corner of that window click on the "Apply" button, which will cause that button to change to "Sync" so you need to click it again to start the Sync process to start.
If a lll goes as expected this will make iTunes copy Bakery Story from your computer to your iPhone/iPad.
