SOURCE: New Rechargable Batteries Die after A Couple of Pictures
This model is renowned for poor battery life. Some people say using the CRV3 battery lasts a lot longer but my advice is to buy NimH batteries with at least 2600mah. Some Nimh are only 700mah and obviously will last less than a third the time of a 2600. Keeping the use of the LCD to a minimum will increase battery life and using the flash puts a tremendous drain on the batteries so if you can do without the flash switch it off. Combine these tips with a set of 2600mah batteries and I'll guarantee you'll be pleasantly surprised. As a sideline I always have a good laugh when I see an Olympics opening at night or a firework display and all you can see is thousands of flashes going off which the majority only reach about 12 feet maximum and the parade being shot is some 300 feet away. BMW
SOURCE: Motorazr V3m gets hot and loses charge
there could be a problem with your hard drive on your phone, or the intercooler in it that has stopped running, there is nothing that you can do about it other than take it back to verizon
SOURCE: Binatone Cordless Phone (2nd set) loses charge quickly
The batteries that are in most cordless phones, and even cell phones, have a "memory". If the battery is constantly being fully discharged from a lack of charging, or if it's used to being on the charger all the time, it will reduce the life of the battery substantially. You'll need to get a new battery, and try to make sure that the phone is placed back on its charger every night before you go to bed. This should allow the battery to receive a full charge each night to prevent full discharge and lengthen the life of your battery. I went through about 2 or 3 batteries once before I found this out. I'm sure that you'll find this helpful and it should save you a few bucks in not having to replace your battery as often. Please rate me accordingly, if it's not too much of a bother. Thanks and have a nice morning!
James
SOURCE: my psp battery loses power "quickly" and charges very slow....
How old is your battery? You may want to think about buying a new one as it may be on it's way out. Even if it is fairly new you might have a lemon of a battery. It happens at times. IF your psp is new and your battery is doing this you should contact sony and see if they can replace your battery for free or a nominal charge.
SOURCE: KU990 Viewty's battery loses charge very quickly
I saw on another forum two good tips.
1. Do not use a case with a magnetic clip.
2. Take off the battery cover and put tape over the two small etched squares that you can see one at each end on the inside of the cover.
I did this and up to now my battery has doubled its life. Still two bars after 1.5 days of medium use.
Terry
