Can't tell if this is the same model or not. Please let us know if it is or not.
https://www.manualslib.com/manual/778629/Titan-Ttb355chn.html
Titan TTB355CHN Operating Manual
SOURCE: need instruction manual
To download the instruction manual, please click on the link:
Gevalia CM-500 Manual
SOURCE: I need a manual for my stihl petrol chainsaw model
you can purchase a manual from store.payloadz.com $ 8.99 they stock manual's for most every model..hope this helps
SOURCE: I would like to know how to adjust the carburator of McCulloch 3516 chainsaw 35cc/cm 46759-77
the carbuator has two 2 adjusting screws on it.one is high side and the other is low side.start by turnig them both in until they touch bottom.now turn them both out 1 1/2 turns.this should start and run saw.throttle saw up to full throttle and adjust high side in until you get the best RPM out of saw.do not adjust high side any less then 7/8 turn out from bottom.if you do you will burn saw up from to lean burn.once the high sie is set now adjust low side until the saw will idle by it's self.let me know if this helped you.......
SOURCE: NEED INSTRUCTION MANUAL FOR MCCULLOCH 838 AS CHAINSAW
Found it at
http://www.mcculloch.biz/int/support/owners-manuals/?query=MAC+838&types=O
Testimonial: "Thanks exactly what i was after,thanks again."
SOURCE: As the chain stretches for McCulloch chainsaw Titan 7
a couple things will cause a chain to stretch running it to tight running low on oil a dull chain over heats it
No not the same model thank you! I have emailed screwfix who have very kindly emailed me a copy.
