SOURCE: Generator won't start
After removing the carb, disassembling and blowing it out (twice) to no avail, got a one gallon can of Gunk Parts and Carburetor dip. Removed the carburetor (again), removed float bowl cover, gasket, float, and needle valve and soaked it in the cleaner for several hours. Blew it out (again) and reinstalled it. Now generator starts on first pull like new!
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
SOURCE: the 2007 hammerhead gt 200 150cc go cart will
if you are getting gas, it's probably too much. is it flooding the motor. make sure your float level height is okay and that your float needle valve assembly is clean and not sticking. if you have an electronic choke, try disconnecting it. it might be malfunctioning. also a possibility your valves need to be adjusted.
SOURCE: i have a coleman powermate premium plus 6250
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
