Question about Golf
Gas will not get to filter while starting EZGo Golf Cart
  • 2,800 Answers
HI...do you mean no gas gets from the gas tank to the gas filter?
Posted on Mar 16, 2018
  • 2,005 Answers
Check your fuelpump and fuelpump relay
6ya staff
SOURCE:
Anonymous
SOURCE: I ned a service manual for a 1995 ezgo dcs golf
Our EZ GO golf cart will start and run except you have to hold the choke about half way out for
it to continue to run. What is wrong?
Posted on Apr 20, 2009
Joe Hogan
  • 10865 Answers
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
Posted on Aug 19, 2009
Anonymous
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
golfcartman
  • 34 Answers
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?func=show&file=200332&Category=100013&Page=1
Posted on Apr 21, 2010
golfcartman
  • 34 Answers
SOURCE: EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
Posted on Apr 24, 2010
Looking for wiring diagram for 1999 TXT EZGO golf cart controller?
There are a ton of them available, apparently:
https://www.google.com/search?q=1999+TXT+EZGO+golf+cart+controller&oq=1999+TXT+EZGO+golf+cart+controller&aqs=chrome..69i57.1143j0j4&sourceid=chrome&ie=UTF-8
Aug 02, 2017 | Golf
Wheres the ground go on healights on a ezgo 3 wheeler
Never had a ezgo 3 wheeler to work on before but sounds interesting. If this is an electric cart then wire ground to a negative battery that gives 12 volts from where positive is connected. If gas cart wire to frame or neg post of battery.
Mar 28, 2017 | Golf
Need a manual for my 1990ezgo golf cart free printable please showing pictures of the carb and filter and gas lines
Visit the on-line store, know as reliable-store, they have the repair, parts and operating manuals. I'm sure you will get the solution of your problem.
ezgo golf
Jul 18, 2016 | Cars & Trucks
I recently came across an ezgo golf cart I noticed I m leaking gas out of the petcock valve and was wondering if I can bypass it?
Hi, Sally I would "NOT" recommend bypassing the valve just replace it for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Product Manuals
GO Golf Cart Parts
Cartaholics Golf Cart Forum EZGO Golf Cart Repair
http://www.buggiesgonewild.com/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 09, 2016 | GAS Motorcycles
Ez golf cart when I go up steep hill the cart loose power and smoke White smoke
Basic EZGO Golf Cart Problems And How To Fix -
www.golfcarthotrod.com > Golf Cart Repair
Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
Aug 02, 2015 | Cars & Trucks
Ez-go golf gas cart only runs when rear wheels are off the gound, why?
It has a level switch that is broken or out of adjustment
May 17, 2014 | 1993 Acura Vigor
Do i need to mix the gas in my 1988 ezgo
Most people do not trust the old oil pump used on the 3PG models, me included. Mix 50:1 and you can be sure that the piston and crank will not seize up.
Sep 25, 2009 | 1995 Volkswagen Golf
Golf Logo
236 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
