SOURCE: codigo sc546 aficio 1035 ricoh
SC546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
SOURCE: aficio 1018d
Try this you will have to enter service mode
clear modes(yellow button@ top)-1-0-7- and hold down the clear/stop button until the screen changes saying service mod, after that, while machine is still displaying service mode turn the machine off and then back on( don't use the MAIN POWER button on the operation panel just unplug the machine and plug it back in) This should reset the code. The code may reappear if there is a problem with the machine but 90% of the time they start working Good luck
SOURCE: service code SC546 on a Ricoh Aficio 1045
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and
then turn the main Power switch Off then back ON... You do not have to
do any thing in service mode, just get to that display.... Don't change
anything unless you know what you are doing. sc546 has to do with the
fixing unit. You may be able to reset it.
SOURCE: how do I clear error SC546 on a Ricoh Aficio 2045
SC546 A Fusing ready temperature unstable The fusing temperature is fluctuating. Thermistor connection loose Fusing unit connector loose you have to go into service mode and reset it
