SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
SOURCE: I have a samsung sensor
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
SOURCE: I have an error code
Hello there
Normally this is a drainage problem code
Unplug the machine and wait for 30 min
During this time Remove the cover on the front bottom right corner or the front cover at the bottom , use the small hose that is attached to the pump to
drain the water, from the pump then unscrew the large drain cover and remove the
blockage from the drain pump. and any additional hoses then reattach the hoses and then plug in after the 30 minutes is up then press the cancel button and test ...Test by pouring 1L water into section II
in the top and setting the machine to 'drain'. it should beging to drain
SOURCE: -I have a Daewoo washing machine DW F1251S with OE error code. What doesthis mean?
Possible this is relative of a poor drain time which means a clogged draining pump and system. So it si best to remove and clean the drain pump/filter and reset.
check if the machine drain hose is connected to a outlet which is not clogged when the water is flushed out . Also the washing machine must be slightly tilted to drain to the pump to reduce the drain timing.
Finally check if the machine was overloaded to produce a strain on the motor so as to give an error. If so shut down remove plug remove load , check if the agitator is jammed and reset.
