Installed a complete TV repair kit and now new problem, it just blows the power board fuse
  • Televison & ... Master
  • 2,005 Answers
You still have a short to ground on your power board
replace the fuse with a resettable circuit breaker and start looking with your oscilloscope or, multimeter for a high amp drain that was blowing your fuses
Posted on Mar 17, 2018
  • 2,800 Answers
Don't use a resetable breaker or you will damage the power supply more than it already is...take a 60 watt light bulb and wire it across the fuse, that way you won't damage anything else on the board when trouble shooting it. Almost all power boards are the same on the hot side where your issue is at...1st thing to test is the N channel MOSFET transistor, generally this transistor is on the heatsink close to the large cap on the board...and see if its shorted from gate to drain..if its bad replace that first, next thing to check is the driver transistor for the gate of the MOSFET, if its bad and I think it will be replace it, now look at the larger low resistance resistor across the drain of the MOSFET, it may be open, then double check all the other parts you installed in the kit, pay close attention to the zener diodes to be sure you didn't put one in backwards..power the board back up with the light bulb and if you have it fixed the light will come on for a second then go off, if it lights bright you still have issues but this way you can work on the board without damaging it...Good luck...another fix would be to order a new power board.
6ya staff
SOURCE:
Benimur
Louie Role
  • 6966 Answers
SOURCE: System won't power up
Based on your description, we can limit the fault to the power supply board and in particular to possibly 3~4 components:
  • bridge diode;
  • filter capacitor (mains);
  • regulator;
  • filter capacitor (secondary).
blown fuse indicate a short in any of these.
As Jaime867 has suggested, in the absence of a readily available replacement board, component level might be the best alternative at the moment. Having posted the most likely culprits further narrows down your troubleshooting. Could you pls post back the part number of the smaller IC either 4 or 8 pins?
Alternately, pls check for the presence of a VDR, it would look like a coin (often green in color or something else) with 2 pins. They have been known to short out also and cause fuse to blow. One possible indicator is chipped or flaked of one side or a hairline crack on top. If it is chip, there would be a silvery color on the inside.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 26, 2008
olayoju victor
  • 191 Answers
SOURCE: samsung le40r74bd LCD TV
hi is the power still coming on? if yes no need for power . have u put anntenal & change the chanels b4 then to see if sound will come .if ye s its yuor backlight inverter u can also disconet ur inverter plug & power on  the tv & change channels if works change ur inverter if dead change your ad or mainboard .
for replacement , lcd parts .com. will help
Posted on Nov 10, 2008
tvtek
Duke
  • 1284 Answers
SOURCE: power board in magnavox 37MF231D blows fuse right
Then you have a shorted regulator circuit. the best bet is to replace the power supply board itself. The part number is 313815864961. Please take a few moments to rate my answer, Thank you.
Posted on Nov 17, 2009
Vito Vacirca Jr.
  • 140 Answers
SOURCE: powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Posted on Jan 15, 2010
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Initially the tv would make an arcing sound and
That chassis is famous for the CL031 box capacitor burning through the board often if the hole is large enough the entire deflection board may need to be replaced as alot or arching can cause a surge to run through the deflection circuits, So replaceing the deflection board as a unit may be the best bet.
Posted on Jul 31, 2011
I installed a complete TV repair parts kit which included three new boards into my Samsung 55" LED TV and now have a new problem,it just blows the fuse on the power board
More than likely had original short that blew the original boards. You replaced the boards, but still have the short that blew them out. Think about having a professional look at it.
Mar 17, 2018 | Samsung Televison & Video
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
ShopJimmy
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
https://www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
https://www.youtube.com/watch?v=4P_0aLDZgBY
Jan 01, 2016 | Televison & Video
Convergence repair kit used but problem is worse
did you check and replace the two pico fuses on the G board and also the six pico fuses on the D board? If so double check the solder often a pins mounting ring will lift up during the removal and prevent solder connection when doing the install.
Jan 01, 2013 | Sony KP-57WS510 57" Rear Projection HDTV
Kdfe60a20 6 blink
Yes the power supply board is notorious for blowing caps and tv repair kits .com has a good DIY kit for this problem.
Oct 08, 2012 | Sony KDFE60A20 60" LCD HDTV
Repair tips for plasma Y sustain board
Ah! if the short shows at the large input filter caps---put the bridge rectifier under a microscope (not literally).
That is in a package which actually contains 4 diodes--even if tests good and is mounted to a heat sink, unbolt it as I have seen a few (line voltage surge) fracture them on the rear--reads ok when set off but when power hits it at turn on it arcs over to the heat sink.
Just a thought--just keep looking if a short to ground--takes time but not usually a major part bad.
May 25, 2012 | Televison & Video
We had a storm last night and the storm blew the power out and now the tv won't work I have tried everything we even went to get a new fuse and that won't work. What seems to be the problem? we...
Did the fuse blow? And when you put in the new fuse, did it blow right away.
For five year old TV, the common failure will be the power supply module and the processor on the main board since it will be running 24/7 even when the TV is off, this make it subject to all kind of surges and spikes (I kill the power my TV's when not in use using my power conditioner power switch).
The main board can be damaged also.
Repair shop will more likely to charge you $50 to give you the estimate, typical repair will be $150 and up plus parts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 14, 2011 | Polaroid FLM-323B Television
I don't have any power to the t.v. even though it's pluged in to the outlet. It's a emerson model EWL20S5B?
Small TVs like this almost always are made up of two boards inside - a power board and a main TV board.
And almost always there's a fuse on the power board, near where the power cord goes in.
Checking that fuse is the only thing you can do by yourself.
Your next option is to give the TV in for repair to someone who fixes such things. Chances are high the problem is in the power supply board and is repairable.
However, the cost for doing so can be prohibitedly high as cost of the TV itself is prohibitedly low. I mean you may be better off selling it on eBay for $50 and buying a new one.
I know I'd buy it for $50 there.
Nov 17, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
No pic but sound
I think you probably mean the Y-Sustain board which does have fuse which can blow. This board is on the left hand side (as you look from the rear of the TV). Occassionally other factors can be responsible for this fuse to blow such as the buffer PCB which works in conjunction with the Sustain board. An established repair service centre or a supplier on-line will porvide a replacement for you.
Jun 29, 2009 | LG 42PC3DC 42 in. Plasma HDTV
Blown fuse 1.25amp Board pos. 1452
The main fuse should be a 4 amp fuse not a 1.25 amp.
Jan 26, 2007 | Philips 32PT6441/37 32" TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
